| Message |
misfiring today and I looked at all the plugs, look identical for wear and swapped around coils from the other side of the motor to see if that made a difference, but still the same thing missing on the driverside forward two cylinders, I am thinking they are gunked up or are bad. When starting the car up for a while now (month or so) the engine would miss at startup and then correct itself after a minute or so. The only other time would be when the gas was low (below 1/8 tank) Think I gunked them up or they are just finally bad. Just want to ensure that what I am doing is correct. from what I read online with it set to 200 the max it can read is 200ohms. As such, with the .7 reading I am thinking the injector is screwed, but want to call upon those who have a better grasp on this sort of thing.
